Longtime reader,`
Hi anangbhai,
Welcome to the forums.
Originally Posted by anangbhai
TMPGEnc Plus (the one I use - good quality, not the fastest, good price)
Mainconcept MPEG Encoder (the one I believe Premiere Pro uses)
Canopus Procoder
Cinema Craft Encoder
Your other option is to stick with what you're doing and check out the forums over at www.wrigleyvideo.com/videotutorial - a great site for most of Adobe's audio / video related software.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks for the help`
No need to export to AVI - frameserve instead. It avoids using a codec, and also the time taken to write the AVI file.
Frameserving is where your source application (Premiere, in this case) "serves frames", i.e. sends them, as they're requested by the recipient application (TMPGEnc in this case).
Be sure to have plenty of memory on your machine... Frameserving is memory intensive, as this is how the frames are passed between applications. At least 1Gb would be good.
An excellent one which I use (and it's free) is Debugmode Frameserver.
If you must save to AVI, save as DV AVI as this is the format that is native to Premiere.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
